CXR autosave
Thank you for all the great effort you do creating Corona.
Assuming that I can playing with lightmix after renders, I’m looking for a way to get some CXR files out from a render queue. “Automatic save on render end” option in Corona preferences only have effect if render command is invoked from VFB. PV and render queue don’t write nothing in History folder.
I’ve noticed also that when CXR files are written, the files are deleted when C4D session quit. This should not happen at least according to Bengamin’s post…or I’m missing a checkbox somewhere?
Choosing a path for “Automatic save on render end” should be an option…
Obtain CXR files from a render queue should be implicit, or I’m a dummy?
I really hope in a better integration of CXR format output, in C4D render settings==> save panel, it would be ideal found options for CXR format.
Hi Team,
Rutg3r
Hi there, thanks for the request. We will make a note of it.
Hi there.
Thank you very much for your feedback.
This has already been reported to the dev team so they can look for a better approach.
Have a lovely day/evening.
Kind regards.
(Internal ID=994202191)
Thank you guys!
All the best,
R
