In max, when saving an image from corona VFB window, you enter the name and type (for example a .png)
and usually you get a new window to pop up - PNG configuration window -
that allows you to check alpha channel and choose different options - RGB 48 bit by default.
It used to work the same way after saving a CXR file and then trying to save an image(render element) from the CXR file.
Since updating to corona 14 this pop up window - PNG configuration - is missing? or needs to be activated?
Is this feature removed or updated somehow?
At times it was helpful saving the CXR file and later saving all render elements.
Does anyone face the same issue?
