Sorry if this has been previously covered.
I’ve noticed that when I render with D.R. and use a region it appears that the slave is still rendering out the whole image…
The only evidence I have of this is that the passes total has begun to read something like: 75 (4). (Usually my slave renders almost 50% of the total passes)
Latest release with max 2018. Happy to provide any further info…
To check you can tick the save sent images checkbox in the DR server and view the sent images.
I believe that currently this is the expected behaviour when using DR with render regions. I can however bring this up with our developers to see if something can be done in the future if you like?
Thanks,
Rowan
EDIT: Logged.
(Internal ID = 377832553)
Thanks, I’ll check it out.
And yes, that would be very helpful! Thank you.
