(Daily Build 2019-04-16) IR + LightMix, LightMix keeps reseting
Again, as the title says :smiley: If you are running IR and use Lightmix at the same time… The Lightmix settings will reset everything afteryou change something in the scene that causes the IR to update.
The settings reset to whatever settings you had when you’ve last saved your C4D scene.
Rock on! :smiley:
