(Daily Build 2019-08-30) LightMix does not recognize the selection of lights
LihgtMix does not recognize the selection of lights,
Regards,
Greg
I am not sure what you mean, can you explain? Turning lights on and off in the LightMix doesn’t affect the image? Adjusting values for color and intensity in the LightMix doesn’t affect the image? Something should have appeared in that list of lights in LightMix that is missing?
EDIT - if you mean the sky is checked but doesn’t show in the image, does it show if Rest unassigned is checked? How is your sky set up? Corona Sky? HDRI? If HDRI, what is it plugged into material-wise?
The same problem. light select sky is not displayed but displayed in rest/ (Daily Build 2019-08-30) Cinema 4d r19
Hi, I can confirm the issue! I reproduced it by creating a C4D Sky object with a Corona Light material with HDRI. Then I added the sky to a separate LightMix pass, yet the light still appears under the “Rest” pass. We will investigate this.
Internal tracking ID: 398410537
