Hello…
So yep, the projector shader still isn’t fixed. It just doesn’t work with the IR - you either loose the texture or it doesn’t do anything when you tweak it. Once you restart the IR then it respects the changes.
Connect this issue with the CBitmap and the Transform issue and we effectively can’t scale bump maps in Corona :\
OS: Windows 10
