I would like to have an auto-horizontal option for the perspective panel. As now I find it a bit tricky, as obviously the camera still not works properly enough.
Indian it is! But seriously, I guess you already know but Chaos Group as a very decent viewport preview of volumetrics using the vrayvolumegrid object. It would save a lot of work and generate compatibility if Corona would be able to just pick up those vrayvolumegrid objects and render them.
(Funny enough I was already using vrayproxy objects in Corona which work fine when you put an ‘convertToPoly’ modifier on them)
Technically maybe not but for all intents and purposes they still load their external content and you can instance them as well keeping a low memory footprint.
But I’m using them mostly to read alembic meshes generated in Houdini into max, for that it works just fine.
Quite a few actually. Main one being the Max is locking the alembic file so you can’t externally update it when it’s used in an open Max scene. Even when you delete the object it doesn’t unlock. The controller setup is a bit whack. You have to apply an abc controller and load the alembic file in there as well. And a quite a few other small small bugs and issues.
I’m the main dev that worked on SideKick ( https://www.ycdivfx.com/product/nyx-sidekick/ ), an interactive bridge between Max and Houdini and I getting it to work properly with Max’s native alembic loader was a nightmare. Vray’s proxy loader just worked fine and has quite a few more options as well.
