I really like this project. Some cool stuff here. Also interesting to see your break down vid. Do you do all your DOF with lenscare? Also do you feel Arion FX gives you much more than you could do in photoshop alone?
Well thanks for the kind words. I usually use lenscare because the amazing bokeh you can achieve with it. About arion fx.. True that you can do basically the same using only photoshop. But for me its kind important the visual feedback you get as you change the settings.. Turns the workflow a bit faster.
Well thanks.. I use blended dust pictures in photoshop! as easy as that.. some times what I do is to apply the depth of field directly to the dust too that gives it some 3d depth feeling
