dark ambient
hello. I do not have much experience with Vray ambient, how I can realise an atmosphere in vray how the image that attached. thanks
  • elemental
  • ambient
0 voters
Re: dark ambient
well, in one sense you’re in luck because black leads black. In other words if you set the diffuse value of a material to pure black (0,0,0) this effectively kills all the light that it interacts with, and therefore will give you a black result. This gives you the freedom to pretty much light you’re scene as you need. One thing of note, you’re global reflections/background will need to be black, but in order to get good reflections on the martini glass, you will need to have an environment setup within that material.
Re: dark ambient
ok Dalomar, I am going to prove your recommendations and to comment my results.
thank you
Re: dark ambient
I’m looking to do almost exactly the same thing, except the back round needs to be totally white and not black. I’m doing a visual of a knife for some packaging.
Can anyone suggest any good scene/light set ups? To make things even more difficult the knife is in a white plastic…and its proving rather difficult. I’m afraid i cant post a photo of the knife/current scene as it is confidential work, but any advice would be greatly apreciated.
Thanks in advance,
Will
