Hi guys! Plz help me out, I am quite new to vray infect but i know all the basics. The problem is whenever i render i get these dark outlines on my renders, please tell me how to fix these.
Please check the attached file.
Many thanks.
Many thanks.
this is the attached image file, please check out
http://www.flickr.com/photos/60260445@N05/8366232227/in/photostream
By default the sss shader uses Fresnel falloff for the reflections; that means that at low angles you see the reflections of the Reflection environment. If you have this set to black, then you will get the dark edges.
Thankyou vlado. your help resolved the problem.. ![]()
