Dark Hero BIOS settings for Ryzen 9 5950X
Hi Guys
If I’m not planning on overclocking, are there any specific settings I should be paying attention to, or can I basically set everything to default in the BIOS?
ASUS Dark Hero, AMD Ryzen 9 5950X
Also, do you guys install all the utilities and monitoring that come with the board, or do you prefer only the chipset drivers?
@Muhammed_Hamed
Hey!
Sorry for the late reply, it has been a busy week for me
Default settings in Bios, then enable DOCP and choose the profile for your memory. Save and reboot
This is all what you need to do, there is a also a way to get better performance with some minor tweaks, called curve optimizer
This is not needed to do, but it is very easy and gets you a better single and Multi-core scores, specially that you have good cooling in your case :slight_smile:
Only Armoury Crate, it has everything you need to install after like drivers and utility software
Here is what I did, greyed out means I checked and installed it
Best,
Muhammed
Nice one, thanks!
