hey guys, i’ve been passing for a odd problem… my vray cant recognize the environment to use it as reflection purposes… it can show me the bg if i leave the afffect bg unchecked, but even while i do it, the reflection of any reflected surface got pure dark. i am using 1.4961 build, somebody have a valid solution to this?
Can you explain this a little better? I’m not sure I understood your setup properly.
A screenshot/render perhaps??
That would help greatly.
hey guys, i’ve solved the problem, the point is that i wasnt using vray camera and vray sky correctlly. the affect bg was unchecked. thanks anyway
