Darken and lighten Material maps
Status: planned
It would be great to add a feature that allows both lightening and darkening of maps. This would offer more flexibility when fine-tuning textures. For instance, if the texture slider is set to 0 in the center, with -100% on the left and +100% on the right, moving the slider to the left would darken the texture, while moving it to the right would lighten it. We’d also keep the invert option, as it would continue to add extra flexibility for adjustments. See image
Submitted on AHA Ideas (ENSCAPE-I-1531).
Can you elaborate a little on your request? What exactly do you mean with “brighter”? Adding more white to the color? Adjustments to the saturation?
Submitted on AHA Ideas.
Hello Joachim,
Thank you for your reply. To clarify, the brightness slider currently ranges from 0% to 100%, with 0% representing black and 100% representing the texture’s base exposure. Ideally, it would be helpful if the slider could extend beyond the base exposure, allowing it to reach white.
For example, if I import a reflection map that has a mid-gray color, the texture will have a medium sheen. Adjusting the slider toward 0% makes the texture glossier, but I cannot make it more matte because the slider doesn’t allow me to lighten the map. As a result, I need to open the reflection map in Photoshop, adjust the brightness there, save it, and re-import it into Enscape.
It would be much more convenient if this lightening adjustment could be done directly within Enscape using the texture brightness slider. Happy to elaborate further if you need more clarifacation.
Submitted on AHA Ideas by Bill Pollock.
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
