darker/deeper shadows?
hi guys
I love the results i get from HDRIs but i often find myself wanting deeper/darker shadows. I find that the shadows are somewhat ‘washed’ - is this some thing that is only achieved in post? I see some great renders out there and i was wondering if there was any method behind this?
Cheers
S
Hi
Lowering this value makes shadows sharper and more contrast. Try this, if I understood your problem right
Coming from Vray… Lowering the gamma of an HDR below 1.0 will indeed create more contrast between your lights and darks, but it will also increase the saturation of the HDR, so be prepared for that.
Likewise… Raising the gamma above 1.0 will produce softer shadows and less contrast, and less saturation
Another option may be to check your filmic shadows in the post-rollout of the frame buffer.
Yes, it will increase the saturation of HDR, but you can control it using Saturation value in Corona Color Correct Texmap. Beside that you can control intensity of light produced by the HDR map changing Exposure value
Thanks guys - i do technique already - i do get mixed results i thought there may have been another technique - it may be a thing to do in post i suppose
thanks again for your help
Might be an obvious one but another route would be to adjust other settings in the Corona VFB… I regularly increase the contrast here to 3 or 4, and then knock down the saturation to balance it out (e.g. Contrast 3.50 and Saturation -0.050), or as suggested some tweaks of Filmic shadows/highlights although I generally to keep these at 0.
