We have a project called Das Phantom. The model is hard to make with Sketchup because of the round figures. The project is likely to go on so in the future it is going to be built. Any comments? We will have to show this residence to the holland beauty commission. So the presentation has to be perfect!
I think if you improve your materials the renders would look a lot better, the grass area seems to take up a lot of space so try using a more realistic grass material, also if you had better looking trees I think it would look much better.
come on, it’s a nice work anyway… it is hard to design,draw the plans and make the 3d model…
Rolfo, i would recomend you to look for a rendering process, and then study it… for example, you have to be very careful with the model, then you go to the illumination, then to the material editor and after you render, there are a lot of things that you can do in photoshop… you obviously know how to use sketchup, so the next step is to lear how to get the right illumination…
keep posting.
its a nice design man what you need to do its improve your quality it thats something you can learn here, and i see that your model have irreegular forms. Keep rendering read tutorials that you cand find here about vray settings and lightning. keep it up bro!
