Hi there,
Any chance of adding a feature to show the date/time clock as you do a solar animation in Vantage. Think Enscape has this capability? Thanks
Hi there,
Hi james_gunn,
Do you refer to this UI element in Enscape: https://drive.google.com/uc?id=1qR-sKnNlQP43DQFECDyQxZeAZg9kZWqK ? As far as I know this is only visible in the viewport and not in the final output video. Currently in Vantage you can see those properties in the Environment tab>Sun rollout, when you scrub the timelime the day/month/year and hour/minutes parameters update accordingly, if you have set a sun animation, Do you wish to have a similar to Enscape UI element in the viewport or as an option in the final output video?
Alexander
Hi Alexander, thanks for your response. Yes, that was the feature I was referring to.
An option for it to appear in the final output video would be really helpful. Many thanks.
Kind regards
James
Thank you, James,
I will log in your request in our system and will notify you when such or a similar feature is implemented.
Alexander
