you can add a small amount of noise to the target of the physicalCamera and turn on motionblur.
This renders an image without an stabilized lens.
The amount of wigglyness is controlled by the shutter speed.
Georg
Georg
ooo, cool idea ![]()
and welcome to the forum!
Sounds cool, but i don’t understand… Add noise to the physical camera target?
i assume he means add a position list controller and then add a noise controller…
Thorsten
Thorsten is right:
Add a “positions list” to the camera_target.position and a Noise controller to the empty slot.
here are some samples:
the same frame with different settings:
Georg
Re: de-stabilized physical camera
and by the noise shape and scale too.
good trick, and welcome ![]()
Lele
Nice method, but i prefer adding a rotation noise controller to the camera itself.. gives basically the same results but works with non - targeted cameras, what i usually use. good values are angles of about 0.5°.
Of course you got to do a liitle “rig” for that by parenting the camera to a dummy, or as i often do, to an istanced cam without shake ![]()
