Deactivate ambient occlusion AO - Cinema 4D
AO is a amazing featured in Corona render for Cinema 4D. But I wish can control it. For example reduce it or deactivate it the render settings.
So my question if there is some way to deactivate ambient occlusion in cinema 4d?
If somebody can support me with this will be amazing.
I’m personally not sure what you are talking about, heh :smiley: You mean the AO shader with which you can use AO to get dirt and similar effects going? Or are you referring to AO while rendering?
If its the latter, well, Corona doesn’t have any “fake AO” - its all pathtracing and UHD caching so it should behave like it does in reality. Nothing to disable because nothing is there :smiley:
If you want to generate an AO multipass element then you can do that via the Corona Multi-Pass menu and add it to your image in post-production.
Sorry if I’m not particularly helpful but I wanted to give it a shot.
