DeadClowns Buglist
I will use this thread for further bugs I may find (if that’s ok).
build 30.8 2012
  • 3dsmax crash when map in emission slot
    _Keymaster: FIXED
  • 3dsmax crash with multitexture map in diffuse slot (which is a plugin but it would be awesome if it would be supported)
  • corona light (rectangle mode) is only creatable in one direction (1st click and drag to several directions). In my opinion it would also be more practical if the light was created with flipped normal direction (currently its pointing towards the camera, so i have to rotate it about 180° everytime.
    _Keymaster: FIXED
  • 3dsmax crash in scatter when distribution scatter objects frequencies are set to 0
    _Keymaster: FIXED
  • I noticed a very noticeable change in the look of the images attached to this post. Especially the bottom part of the humming top looks very purple now. Left image is alpha v2, right image is build 30.8 2012
I’ve prepared a little scene (no maps) which should be perfect to test those things. The scene is saved with alpha v2, the 30.8.2012 version is made by opening the scene and pressing the “production defaults” button :wink:
I’ll look at the other bugs when I have the time (in 1-2 weeks).
The color change is in my opinion because the internal color space of Corona was changed from sRGB to XYZ. Because XYZ gamut covers the entire range of visible colors, it allows Corona to deliver more accurate results than other renderers in situations, where extremely vibrant emissive colors are created (blackbody emission <1700K, sun at sunset/sunrise, heavily colored refraction attenuation, sky models near horizon (even in the middle of day)). The result still needs to be clamped and converted to sRGB, but the internal calculations are in XYZ, so the clamping is only where absolutely necessary.
Secondary effect of XYZ is that its primary colors are imaginary - they do not represent any real colors, they cannot be reproduced or perceived. This means that you never encounter for example XYZ(1, 0, 0). Such types of RGB colors (e.g. RGB(1, 0, 0)) are common, and cause many problems during rendering. XYZ transforms 1 0 0 to 0.41 0.36 0.18, which is much better to compute with. I will demonstrate with examples:
Scene lit with neutral light: there is practically no difference between RGB and XYZ:
Now lets light the scene with purely green light. Since the right wall is RGB(1, 0, 0), and the light is RGB(0, 1, 0), its component-wise product is RGB(0, 0, 0), which is black. XYZ handles the situation much better, since there are no purely monochromatic colors after transformation:
Blue light: same story, this time both walls result in black when using RGB:
Blackbody radiator which emits mostly red, but also other colors: since the left wall is RGB(0, 1, 0), it cannot reflect anything other than green. Because of this, the wall remains green and does not take any tint.
Now, back to your scene: I am guessing, since you are using blue object color, and yellow lighting, which is complementary color to blue, that in the RGB the colors are not mixing, and lighting is not affecting the color of blue object. In XYZ, the blue object is tinted (as is everthing other in the scene), producing the purple.
Now, what is “correct”? The answer is both - because the term “blue” can mean a wide variety of very different spectrums. XYZ just uses one that is not as extreme, resulting in more plausible shading, but occasionaly less vibrant colors, when it is needed for the material to correspond to the rest of the scene.
Thanks a lot for your explanation. I didn’t know there was such a technique as xyz. It sounds convincing! I thought about this blue color - orange light mixing too but I’m accustomed to this rgb look from vray and other renderers, so it looked a bit weird on first view :wink: I’m sure it’s a good technique so I’ll do some experiments with it.
Found some other weird things here:
  • Some sharp edges on smoothed surfaces. Seems like some polygons which share a specific angle are not smoothed correctly (best visible in the directlight pass)
  • 3dsmax crash when viewport is set to a corona sun
    _Keymaster: FIXED
  • Some random objects (in a scene with many many instanced objects) don’t have correct uvw coordinates, resulting in wrong mappings. Some seem stretched, others seem to place the whole bitmap on each of the objects polygons. I’m not sure if all of these instanced objects have the same stretchings but it looks like they do. It renders correctly in other render engines and maps are correctly displayed in the viewports.
    _Keymaster: FIXED
I can provide some images if that will help to nail down those problems
Ok, I’ve fixed what I can from this thread.
Open issues:
  • Viewport set to Corona Sun display does not crash now, but displays nothing. I am not sure what it should display, and how to change it, so I’ll leave it
  • Sharp edges: those are from shading/geometry discrepancies when using sharp light near grazing angles. I am not sure if that could be fixed. I dont know any solution, you’ll have to make the geometry denser, when this appears.
  • Crash with multitexture: I’ll probably need to contact the developer of the plugin. It requires certain informations Corona is not storing to conserve memory. I’ll probably need to add them later anyways.
That was fast fixing O_o
Viewport sun thing: No problem. It can be useful to see which part will be in shadow when viewing through a direct light (or sun light) try that with a direct light (i’m aware of the fact that it is a bit “tricky” since sunlights don’t have an affecting radius or something). Anyways… Crashs are always bad :tongue:
Sharp edges: Not a big problem but seemed to appear a bit earlier than with other renderers
multitexture: Its not a veeeery stable plugin anyways but i love the color variance stuff… Maybe I should transfer that to a wishlist item (randomly color correcting (and offsetting) an input map per object ID, material ID or node ID). Would be a such a nice combination of bercon map and multitexture.
