I am trying to render using hybrid with commandline for deadline
I tried all the option
-all -rtengine options
-vray-gpu settings
-environment variable
Any other suggestion?
Thank you
Fred
-vray-gpu settings
Thank you
Fred
Hi, thanks for posting. You have to set up the devises to be used on your slave machines. You can use the Device selector for this task. It is the same procedure as for GPU distributed rendering.
