Hi Chaos Team,
V-Ray crashes every time I start scenes with Decals.
I got this issue since the last Update.
It worked fine before the update.
I´m still using C4D R21.
Is there any workaround?
Hi Chaos Team,
Hi @Rickmc , can you share a bit more details about your scene setup? We are aware (and working on a fix) for some crashes relating decals with displacement when they are applied over multiple cloned objects. If your scene does not have such Decals, could you share it (or a simplified version of it) so we may take a look?
Sorry for the inconvenience.
Hi Dean, here the simplified Scene.
The Decals are unenabled.
I get always a crash as soon I enabled them.
DECAL_FAIL.zip (363 KB)
Hello @Rickmc ,
Thank you for providing the scene.
We managed to reproduce the crash with your scene and we will be looking into what might be causing it. We will get back to you as soon as we have more information to share. Thank you!
Hi Deyan, no excuse needed.
You guys doing a very good Job.
Most companies sould learn a lesson from chaos.
Thank you very much.
Happy Weekend
