Hi there,
Are these on the “to do list”?
Also light direction and decay - use it a lot now that it’s available in vray?
Hi there,
Hi philip_nel,
All of the mentioned features are in the TO DO list with Displacement in the lead of priorities. By procedural textures do you mean for bump and opacity? Because they should work in any other material slot that is supported. Light directionality is supported can you give an example where it doesn’t work for you? Light decay is also in the TO DO list with no ETA at the moment.
Alexander
Thanks for the reply Alexander.
Yes, those 2 slots I use all the time.
I didn’t pick up on light direction, did a quick test now and it’s working - thanks!
Looking forward to see what will be implemented with next release…suppose it’s a waiting game.
Just hope I can test “TO DO list” updates before subscription runs out - this will hopefully convince company to buy a Vantage subscription.
Is Enmesh support something that is comming in the near future?
This because it’s now supported on the Vray GPU
I’d be interested to know if Enmesh support is coming too. It’s a very useful feature in cpu but haven’t fully dived into using it across the board yet. Vantage support would change this.
Hi guys,
We have it logged under LAV-1140 but cannot give ETA and it is not in the near TO DO list. However I will try to raise its priority.
Alexander
Hello, when I apply from the Cosmos gallery → 3D Models → Enmesh -Pattern to a solid in SketchUp, it doesn’t display in Chaos Vantage. Does anyone know if this can be resolved?
Hi alejandro_ledesma,
We need to add support for Enmesh models in Vantage for you to see it properly. I will try and raise the priority.
Alexander
