Hi - struggling a bit myself - but is it possible to just use the decal as a displacement stamp only? i.e. no diffuse or any other component just the displacement map loaded in?
Not at present, no, since it has to have a Material assigned and the Material contains Diffuse and everything else.
Ok thanks. Would be good if it could in the future. It would be perfect for what I need to do (car wing with indent for a badge)…
Did you use the displacement as the opacity mask too? I tried that but because I need a close-up there was a fringe that I couldn’t get away with - but it would have been ok for a distant shot I think…
Thank you
I think I used the same crack texture, inverted and maybe more contrast. I’ll zoom in and see how it looks.
Thank you. Yep pretty much what I tried just without the contrast.
