Decal not showing on layered materials.
Hi guys. I am having problems with the decal its not showing on layered materials? is this a bug or are decals not meant to work on layered mats? I have attached a file.
Decal Bug.c4d (328 KB)
Hi, if you render your scene, you should get the attached error. In this case, Decal doesn’t work because the object’s material is Corona Layered Mtl, not Corona Physical Mtl. Note that the issue only appears if you use custom “affect material” options in the decal.
I understand that in this case we would expect the decal to work because the materials applied to the Layered Mtl are Physical materials, so I have reported it to devs as (Report ID=CC4D-1107).
This is now moved to the ideas portal to find out how desperately it is wanted and by how many users: Apply decals to other materials than Physical | Corona Ideas Portal
The usual disclaimer: the link won’t work before it is accepted by Tom.
