Decal on a rigid body
How do I stick a Corona Decal to a rigid body? If I add it as a child of the rigid body is falls off the parent.
Hi there, as far as I can tell, this seems to be broken and will need to be investigated further. Thanks for the heads up.
Hi there, you need to set the collision inherit setting to ‘‘None’’ and it should work as expected. I hope this helps. :smiley:
Thanks :slight_smile:
You’re welcome!
