Decal - opacity - bend issue
Hi!
For example I have a HEAD logo and I’am using opacity for it. When I put the material to a Decal it works, but if I use the Bent - with function under the Decal, it doesn’t work. It turns white.
Anybody met this issue?
head_decal_issue.zip (147 KB)
UPDATE: It doesn’t work with a simple picture inside a diffuse channel. The original picture was a .psd. but it doesn’t work with a simple png.
Am I doing something wrong? Could somebody test it?
Thx!!
Did you try to render and see if it’s only an issue in viewports or if it affects rendering as well?
Hi!
Thx for reply! Final VFB render has an issue too.
(Cinema 4D 2026 1.2, Corona 14 Update1, OSX Tahoe 1.3)
Works fine on W10; Cinema version • 2024.4.1; Corona Version • 14 Update 1 (Hotfix 1).
VFB Interactive & Final, too.
