Decals can't be excluded from lighting
As the title suggests this doesn’t work, which is a bit of a bother.
Specifically the example is labels on bottles, where the label needs to be often
separately lit.
It would be great if this worked :slight_smile:
I made a note about your request for our developers to look into. However, what would you expect as a final result ? For example, if decals don’t have masks included, should they be entirely excluded by their gizmos from lighting or in case they do have masks, what result should be expected and etc.
Philip
Thanks. Normally I’d expect them to be excluded either with/without a mask.
