Decals crash Max when using Cryptomatte Elements
Don’t know if it’s just me but I am getting consistent crashing when using VRayDecal in combination with the VRayCryptomatte render element. To be specific, it doesn’t crash when using ID type “Node name” or “Node material name” but the other three always seem to crash Max (2021). This happens for both the interactive frame buffer and straight rendering.
I can’t reproduce it here, can you send me a simple scene for this?
Email sent! Thanks for looking into this Peter. The file is literally just a default blank scene with a sphere and decal with Cryptomatte elements loaded. I have a feeling it wont crash for you if it didn’t before but hope this helps.
This is fixed in the stable nightly builds starting with build 31072 (https://nightlies.chaosgroup.com/mai…e_5.2/20211029)
Sorry for the inconvenience.
I had the same issue, works fine now, thank you!
Just wanted to confirm that all is well. Thanks for the quick fix!
