I have found out that decals are not visible in masks (RGB, monochromatic, Wirecolor and ID (Material ID)), even if the option is checked on their properties. The only exception is Mask ID with “Instance ID” selected.
Corona 9.1, 3ds max 2023.3.3
Currently, Decals are only visible using the “CMasking_ID” render element (Only if the Instance ID option is used).
We already have a feature request logged in our system to provide extended support for the “CMasking_Mask” render element too.
(Internal ID=1109050825)
Alright! Thank you.
Cheers
