I’m running into an issue here where if I try to save out a deep EXR sequence in max using the V-Raw raw image file dialogue in render settings, the images just don’t save. If I uncheck the deep EXR and just save as regular EXR everything is fine. I can save all render elements to single file from the VFB as an EXR for each frame but obviously can’t do that for 600 frames.
Hope that makes sense.
