Default VFB Save Location (MacOS)
Hi all,
I just wondered if there was a way to change the default save location from the frame buffer? I couldn’t find anything in the prefs. At the moment it takes me straight to this folder:
/Applications/Maxon Cinema 4D R25/resource/modules/cadexchange/libs/macos
Do other people have the same issue? It would be great if it took me straight to the same folder as my .c4d file.
Thanks in advance.
Tim
Hi @KernitTheFont ,
I think you need to go in to the VFB settings. It’s tucked away under the options tab in the VFB itself. Is this what you mean?
Thanks Mark, but I’ve had a look in there (also in advanced settings).That just saves the VFB history window preview vrimgs. (My History folder path is saved somewhere else anyway)
Basically when I choose any of these options, I get taken to that obscure path. Weird.​
Here it simply use the last saving path (C4D R2023, Vray6, MacOS 13.0.1).
