Delete only V-Ray attributes
Add a menu command that removes only the specified V-Ray additional attributes, such as V-Ray Maya and Modo.
Yes, this would be great to have either a shelf tool a command that we use. I rather have a shelf tool that removes the obj properties, like Arnold.
yes, please! +1
The option to delete “V-Ray Object Properties” will be available in next nightly build. It is located in Menu Bar > V-Ray > Object Properties > Remove V-Ray Properties
can this also be done for all other properties and the physical camera as well?
Thank you for your prompt response !
