denoise in corona 13 for image sequences.
I’m rendering animations using EXR sequences with Corona’s high-quality denoiser enabled, but I’ve noticed that while the previews on the render farm nodes are denoised, the saved output files are not. When I monitor the renders in real time on the nodes, the “Denoise” checkbox appears to be unchecked.
Is this expected behavior? If not, is there a way to ensure the denoiser is applied to the final saved images?
Do you have the “denoising” checkbox enabled in the VFB?
Other than that:
What exactly do you mean by “previews”?
