Denoise in VFB not enabling
Has anyone noticed denoise not turning on in VFB?
Iv enabled denoise in render settings but in VFB its always turned off? With older corona versions denoise in VFB would automatically enable when turning it on in render settings.
You can enable denoise after render or during render time if you rendering locally but its an issue if you sending it to the render farm. Denoise wont kick in unless the box is check in VFB even if denoise is enabled in render settings.
This issue has ben fixed in Corona 12 hotfix 1: https://forum.corona-renderer.com/ Corona 12- denoiser turned off #msg227083
Thanks dude!
