Denoise render elements on by default
Im not sure if everyone thinks this would be good. But i certainly would like it if the denoise was set to full denoise by default and was enabled for the Light select render elements by default too. Just a small annoyance when i forget to enable it :smiley:
Don’t know about denoise in RE, but denoise state in render setup, can be saved with new feature “save defaults”.
  • 1 for “denoise on” as default in RE. This way RE will follow the “master” denoise settings, unless you actively wants it different.
Brilliant thanks for that :smiley: Still would love it in the RE though!
@Corona Team, i think short introductional tutorial about save defaults, wouldn’t hurt ;]
thought exactly the same romullus :smiley:
Good Luck
Thanks for the idea! It’s sometimes easy for us to miss such quick, but brilliant tutorial ideas!
Then maybe in the same tutorial add a short sequence about adding those frequently requested two buttons to a toolbar: one to show CoronaVfb and another to start Interactive rendering.
Good Luck
I asked around about this, and it seems most people prefer REs to not be denoised by default, so I am closing this down
