Rebusfarm do not accept the denoise yet. It worked before.
Can help me?
I can not aplly denoise with Corona Image Editor without do process with denoise switched on.
Thanks,
Lino.
And it also doesn’t support Corona EXR, which I don’t know if it’s supported in distributed rendering at all. You should write to Rebusfarm, they are quite responsive.
Yes, contacting Rebus directly would be the best solution. They are very responsive and provide great, easy to understand answers.
I have just contacted them and was informed that for now denoising is disabled due to some technical difficulties - it is probably better to end up with good looking non-denoised image, than with one which is denoised, but has some artifacts like seams, and cannot be used anywhere. I am sure that this will be soon sorted between our team and Rebus, and you will be able to use the CXR format and denoising without any troubles.
Any advice on processing an animation from rebus. Without denoise, we will have to severely optimise the scene.
Is there a way to output a file from rebus that can be processed through corona to denoise?
