HI, im considering upgrading to vray next, but i have one issue which id like to know the status of.
i did an animation with gpu recently, and i was unable to use the denoiser, since it was mucking up everything that was visible through the massive window i was looking through. this meant my rendertimes were enormous and i spent a fortune at a gpu renderfarm.
i was told this was due to gpu not supporting the “affect channels” setting in refractive objects, meaning i got no render elements for anything behind glass.
ahh thats a shame.. is it somewhere on the to-do list? because being unable to use denoiser and gpu when there is glass in the scene is rather limiting.
By this thread I discovered the possibility to get mat ID colors through glass. That’s great!! It wasn’t working at the old Vray for Rhino, where I missed it a lot. At VfR next it works very nice. My hope was to use the fast GPU mode for my watch design renderings and so I hope, the “affect all channel” option will work in GPU mode too in the future.
I’m curious what ill effects you were getting using the GPU + denoiser + glass?
I recently ran through a scene with Vray Next trial and GPU. I found the denoiser made the glass of this particular arch viz project look ‘frosted’ in an undesirable way. It was the first time I’ve had a client comment on image quality, actually, which was unfortunate. He was displeased with noise inside the building even after a significant number of passes. He commented my previous projects I’d done for him were much more ‘pleasing’ when it came to ‘grain’ and also glass representation. I hadn’t loved the denoiser results due to its effect on glass so I initially sent him the nondenoised/high pass version. After he balked at the grain, I sent a lightly denoised version (blended in photoshop with non-denoised to fine tune it) and I got the impression he disliked the denoised version due to the blurred/frosting of the glass. Combine that with the white squares you get with fireflies (if doing progressive and fewer passes mostly) and it leaves you in an awkward spot on some scenes.
Were you seeing similar results? I’d be curious to know if it’s just me being hamfisted or if these are expected pitfalls.
I tend to feel the same. Speed seemed fast but performance with glass was odd and interaction with denoiser was disappointing. What does speed matter (as measured in passes) if you don’t get the result you want and can’t denoise? I would love to hear that I’m just missing something and this performance is not expected.
