HI there
I am testing out the denoising feature and I have run into an issue with my file. If I want to denoise separately as its an animation when i run the tool I get the following error.
If i set it to denoise as its rendering then its ok. I am using max 2018 and using the vray frame buffer.
warning: worldPositions render element not found.
warning: worldNormals render element not found.
warning: Noise levels render element not found.
