Denoiser pass totally black
Hello;
I have a problem with the VrayDenoiser pass, is black in the final result.
In VRAYMESSAGES appears this warning:
Worldpositions and Normals render element not found
Noise level " " not found
My settings.
- Preset: Default
- mode: Show denoiser result channel
- type: Denoise render elements separately
- generate render: Depending on denoising type
any idea?, is a bug?
Thanks,
3dmax 2018, Vray 3.6, Windows10
That’s very strange, is that happening on every scene or it is tied only to that one?
If yes is there a chance to send it over for investigation?
Only happens in a this scene, it´s very rare because if a merge all the objects in a new scene and happens the same.
The scene has a lot of objects and polys. I don´t know is a reason.
The problem is that my scene has a 4GB size.
Thanks.
You can share it via Gdrive or similar service or to contact us and request access to FTP server.
Whatever you decide to do send us a link to this thread for a reference.
I had found the problem, but i don´t when happens. The problem is the RENDER SETTING has a problem in a certain moment and the DENOISER appears totally black.
The solution is change the engine, for example to Scaline Max RENDER, and return to Vray 3.6, put again denoiser settings and your preferences render.
Thanks for all.
