This is simple request of a button to push the denoiser settings from the VFB to the Render elements setting. The reason being we tweak the settings from the VFB and it would save time having to copy and paste those to the render element.
Also it would be useful to have a sticky option for the denoiser. So basically its stays disabled when set from the VFB so that when you initiate the IPR / production render you don’t have to keep toggling it off each time but you still want to keep the settings.
Maybe a double click on the denoiser layer could set this.
Yep, the settings push makes sense, we’ll see how easy will that be.
For the disabled “state”, you can just turn off the “Autoswitch to effectResult” in Settings/System or set the “Post effect rate” to 0.
btw which settings do you want to push to the RE?
@matanov Thanks for replying I didn’t know you can set a disable state in that way.
In terms of the settings it would be the preset that is currently in use and the custom settings.
