This week at last I upgraded to Vray Next.
So today I decided to try the denoising tool as I want to denoise an animation sequence.
I add the Denoise Element and under Mode I select “Only generate render elements”
I save the sequence as an open exr and add the VrayDenoiser element under render elements tab.
I render the sequence and I load the VrayDenoiserTool and select the sequence.
After I hit denoise I see that there isn’t any denoise applied on the image. It just makes a new sequence but with the same noise.
What am I doing wrong?
Ok solved it.
I had to enable Vray Raw image file.
