So, it doesn’t look like de-noising affects elements, how are you guys compromising so you can composite using elements like the reflection pass etc?
Render element denoising is planned for the upcoming versions of Corona.
On a similar note, does denoising work with strip rendering? Each strip gets its own denoising and causes banding in the final assembly. Is there a way to make this work?
