Denoising Rest (unassigned)
Is it possible to Denoise the Rest (unassigned) LightMix channel?
In the Corona Image Editor once I hit Custom Denoise I can’t see the option to tick the Rest (unassigned) LightMix channel.
Thanks in advance
Do you have denoise activated in the render settings?
The “Rest (unassigned)” layer can’t be denoised (at least at present, but I believe that is a technical limitation, else it would be denoisable already). That applies when denoising in the VFB, or later in the CIE.
Then denoise the affected passes, shadow, diffuse, indirect etc etc..
But I think I’m running against a fucking wall here as the majority seem to just use the beauty pass+tone mapping.
