Depth of Field - everything is blurry!
hi there,
maybe you can help me. i tried to render an image with the DoF-Tool from vray.
i tried a lot of numbers and used the tutorial of nomeradona… but i wont work, everything is BLURRY…
i think it doesn’t understand the “override focal dist”-order i give to vray…
i work with milimeters (europe-standard) - my ‘sharp’ element is 1300mm in distance to the camera, this are around 52 inches.
look at the attachements, maybe u can see something i did wrong?
THANKS FOR ANY HELP ANS USEFUL TIPS!
do you want to share to me your scene.. i will see it.
here it is… thanks for haveing a look at it!
http://www.those.ch/transfer/glastest.zip
I looked at your scene and the problem is that your F-Number is too low. You have to increase the F-Number. I tried with 14 and the DOF came good. You have to be aware that the F-Number also control the exposure. So if you increase the F-Number you will get a darker image. You will have to decrease the Shutter Speed or increase the Film ISO to compensate the exposure.
Best
Exist a good tutorial of Dbrenders, but now unfortunatly I can not find the link! :S
I found this, may be it will be useful! :wink:
Hi
This is anotther very good tutorial that explaind how to deal with EV.
hi Fpedrogo! :wink:
thanks a lot for this excellent tutorial of Ciro Sannino! :wink:
especially the importance of the “apertures” because although with different values ​​if get the same amount of light exposure, in accord with some experts say, the resulting image is not the same, at least, in real photography!
Here’s another articles on F-stops in vray - http://joconnell.com/2010/12/depth-of-field-in-vray/
Here is Dbrenders tutorial
thanks to all of you guys, i will try this next week!! thank you so much :smile:
hi there, i tried again - and failed. my render output is everytime blurry. i have no sharp element in my rendered image. as u told me i tried with F-Number 14 and ISO200 - nothing happened. the result is still blurry, not that heavy like in the first post, but blurry… is it, because i am working in milimeters? i can chance every number several times, but the rendered image is blurry in any way!
i changed the FoVoverride from 1 to 20, 38 and up to 100 - everytime the same image… WHAT!!! =D
check your “Override Focal Dist” - this is the distance from the camera to your focus point (in inches - multiply by 25.4 for mm) Need to have that box checked to use a specified distance.
i have always checked the box “Override Focal Dist” - the camera is around 1020mm distance to the glasses. so, as u says, it has to be around 40 inches.
other prefs: aperture 1.0 / center bias 0.0 / shutter 12.0 / ISO 100 / F-Number 14
still blurry picture… i don’t get it =/
Did you just say this “is it, because i am working in milimeters?”
Why are you using inches there, but working in mm?
sketchup model units are inches, so the units in the vray dialogue boxes are in inch.
everyone says that, i hope it is liek that… :slight_smile: still trying to figure out the problem - no can do… any more suggestions?
I just tried your file and loaded the standard render options. I changed the focus to 52 and aperture 14, iso 400, shutter 50 and it worked.
glastest.skp.zip
i have now tried the exactly same file u posted here. if i hit render, vray crashes…
if i export the render options and load it into my own file, vray is working with ‘monte carlo’ renderer and the image comes out very dark…
if i rearrange back to my render options (light cache and turn back the skylight on - that was black in your options i imported) the image comes ok, but with unchangeable focaldistance.
so for now i take your options and change some numbers. maybe it will work…
thanks for helping in any ways… u r grat guys =D
Hmm, strange, what version are you using? Maybe that causes a problem?
i use SU v8.0.15158 and vRay v1.49 - i think it’s everything ok with this versions.
the funny point is, now i have a focus-effect, but i cannot edit it. if i change the inches-parameters in camera-prefs, i can’t see any change in the render-output.
now i try to change the wohle plan, convert in inches. i have a difference: now everything is as sharp it could be if i render with the same options… i don’t get it! xD
