depth of field: grainy dots in unsharp areas
Hi there, did anybody recognized grainy dots in a scene with depth of field? Looks terrible :confused:
Cheers
Tobi
Hi @steilvorlage.de ,
Having a look at the scene would allow me to better advise you on what parameters you will need to change but reducing the noise threshold of the image sampler should do the job. If the grainy dots are still present, please send us the scene to have a look at. Thank you.
Thank you, I will have a try.
Hi Aleksandar, found out that is has to do with GPU rendering in combination with round edges in shader. So either CPU rendering or no round edges.
Cheers
Hello @steilvorlage.de ,
Thanks for the additional info. Even when testing with V-Ray GPU and round edges I was not able to reproduce those artifacts. Could you please share a test scene so I can have a look and report a bug if necessary? Thank you.
without textures, but same issue
test3.zip (102 KB)
Apologies for the delayed reply.
I had a look at your scene (and managed to reproduce the issue on a new test scene) and it seems that the issue is only caused when using metallic materials and having the Camera type (in the Overrides tab of the Render settings) set to Pinhole. Changing the camera type to Standard seems to resolve the issue.
I have reported this issue (bug ID: VC4D-1620) in our internal bug-tracking system and I will keep you updated on its progress.
Thank you.
Thank you Aleks
