DEPTH OF FIELD problem
Hello. I am looking for camera DOF feature. How to set up it in 7.2 ? Any special tutorial is needed ? I tried classic camera depth of field.. no effect.. Corona renderer DOF camrea override.. no effect .. Mental ray DOF.. no effect … HOW ? please help me
I found solution.. Need to use CoronaCameraMod on default max camera.. and set up it
uf…oooook
you probably enabled it, but the effect size was too small - try tweaking f-stop value, and make sure your scene is in correct scale. If it is not, then you will have to change also the sensor width
thank you.. f-stop value is most important.. i know.. 2 is in mental ray real focus value in interior photos.. I will try 2 also in corona.
ps: Corona is more more more faster then IRAY i used.. after long period still grain… Corona interior on my notebook about hour and clear :smiley: in HD … super
