I’m wondering if I’m missing something:
Rendering DOF via DR works only in the first frame. See the pictures:
1st frame works
2nd frame is wrong
Scene attached (latest build). Thanks for a tipp - klex
dof test 01.zip (73.1 KB)
1st frame works
2nd frame is wrong
Dear @klex167 ,
This is a known issue that has previously been reported in this thread. It has already been reported to our developers (bug ID: VC4D-915).
The current workaround is to activate the Depth of Field both in the V-Ray Physical Camera tag and in the Camera rollout in the Overrides tab of the render settings. This way you will ensure that the depth of field is rendered correctly both locally and on your server machines.
I will let you know once we have more information on the matter. Thanks.
Hi Aleksandar,
thank you for the quick answer. Its working this way!
Great!
