Hello guys, I want to focus the blue box and to blury just a little bit the trees and everything around the box, I watched tutorials but I still dont understand how this works, Can anyone tell me please what parameters should I change to make the result that I want.
Lower your F-stop. Something like 2 should produce more DOF. Also, to increase the effect, lower your Field of view.
Keep in mind, you wont be able to fully achieve the look you want, as the box is big and it’s close to other objects (the DOF works on distance from camera, not distance between each respective object).
My tip; learn some real-world photography basics first ![]()
