Am I missing it or is there no way to adjust Saturation settings in HDRIs applied to Dome Lights?
Hey, SharkNinja,
Thank you for the post. I think you can add V-Ray Mix texture and next to control the saturation by texture, color or mix value.
Cheers,
You can also use the C4D filter shader
Hi @SharkNinja , you can use the Filter shader for adjusting brightness, saturation and contrast. There are no dedicated options in the Dome light object for these.
