Even if it falls over everytime you try and sit on it!
Going to adjust a bit tonight and make it a bit more stable looking.
I should be able to get one made fairly easily though once I’m happy with it.
(Err…where you joking?)
Might get one made for a laugh!
i like like practicality in my chairs hehe. this one i use isnt as comfortable as the other one however it rolls better and i roll alot between computers
Still looks fairly unstable to me. I would think that the leg would need to go/stretch further back, but then you ahve a problem where the front is unstable and if you lean forward for any reason … you end up on your face. hehehe
don’t really know whether my opinion is right or wrong, but look at the elevation, if the tip top of the chair is given force form the right, what is going to hold the chair from falling backwards..
perhaps it would be nice to have the back piece made from the cut-out and follow the exact same profile as the leg piece…that way you could laser cut the back piece from one piece of sheet, and do the bending for the back and the leg sections at the same time… just a thought!
also, you’d need to put some sort of feet onto it ideally (can be really small pads set in from the edge or something…) to stop it hight pointing on the underside of the base plate.
Thanks for the tips soreal. Kind of got a bit lost in your explanation. Will add some kind off feet. What furniture have you designed?
Little update. tweaked the geometry of the legs again, and added a fillet.
Looks a bit more sturdy. Hey you could almost sit on it now!
@geoff
sorry about the explanation, got a bit carried away, think it’s probably best to just leave you to it!
i trained as a furniture designer at uni (loughborough) and graduated in 2000. since then i’ve mostly been working as a visualiser for an exhibit design company…not time for much furniture design unfortunately, although it’s something i intend to get back into in the future.
here’s something i’ve been working on recently though, a side table.
hopefully going to build a working prototype before christmas.
are you designing furniture for production or just for fun?
